Where Does This Wire Go
Old Mar 30, 2017 | 03:50 PM
Qfly's Avatar
Default Where Does This Wire Go
I just came across the wire shown in the pic and was wondering what I missed when I put the intake manifold back on.
The wire has been like that for the past three years.
Thanks
Old Mar 30, 2017 | 03:58 PM
98CayenneT/A's Avatar
Looks like it is for the knock sensors
Old Mar 30, 2017 | 04:23 PM
Qfly's Avatar
I thought about that but my HP Tuner showed a degree or two of knock on my HP log which means the knock sensors are working.
One last thing.. In HP Tuners, while logging, the oil pressure shows -15.4 psi but the gauge is working on the cab.
Weird stuff..
Thanks!
Old Mar 30, 2017 | 04:34 PM
EVAP solenoid where my finger is pointed
Old Mar 30, 2017 | 05:47 PM
Majestic9C1's Avatar
The Evap solenoid connector is Red
Old Mar 30, 2017 | 07:51 PM
Qfly's Avatar
I did remove the air and egr when I had the manifold off. I wonder if that connector was left over after the removal?
Old Mar 30, 2017 | 08:35 PM
babbage1109's Avatar
My guess is from the air system.
Old Apr 1, 2017 | 04:13 AM
ReFtheMC's Avatar
Yup. Connects to the EGR Solenoid. Be sure that you capped the Vacuum line that connected to it behind the intake OP
Old Apr 3, 2017 | 09:01 AM
Qfly's Avatar
Vacuum line is capped off and thanks! I had the manifold off three years ago and sometimes it is hard to remember where everything went
I need to wrap connector, label it, and secure it properly.
