Exhaust Question??
Old Jun 26, 2004 | 03:31 PM
99'Formula's Avatar
Default Exhaust Question??
How does the Magnaflow cat back compare to the Borla Cat back? I'm thinking about gutting my cats and I can get the Magnaflow for free. Any ideas on what I should do?
Old Jun 26, 2004 | 03:35 PM
16nrollininaws6's Avatar
Get the Magnaflow. Number one its free, number two, it flows better.
Old Jun 26, 2004 | 03:58 PM
jrp's Avatar
jrp
SN95 Director
keep the cats and get the magnaflow. my clip in sig.
Old Jun 26, 2004 | 08:00 PM
99'Formula's Avatar
Does a Magnaflow flow better than a open plate Borla?
Old Jun 27, 2004 | 12:25 PM
txhorns281's Avatar
Well, since you already have the Borla I say keep it on there.... You're not going to gain or lose any significant amoutn of power by switching catbacks.... (except for slowmasters... haha) I say keep the Borla just to not have to deal with putting the Magnaflow in... if you can get the MF for free then sell it off or something...
Bout yer cats, just keep em like they are, unless you like raspy *** poppin exhaust... If you do LT's later on you can decide what to do about cats...
Old Jun 27, 2004 | 11:38 PM
JamRWS6's Avatar
Flow better than a wide open Borla......I don't think so.
Old Jun 28, 2004 | 11:04 AM
99'Formula's Avatar
I already have LT's and a QTEC so will it still be raspy if it all goes through the muffler?
Old Jun 28, 2004 | 11:16 AM
Velocity's Avatar
If you have LTs and you have high-flow cats on, I don't think the rasp is that bad. If you remove the cats and put off-road pipes in their place, the rasp will be there. If you gut the cats, the rasp will be unbearable. Don't do it.
Old Jun 28, 2004 | 12:37 PM
cyphur's Avatar
don't do gutted cats. keep the borla, there's not enough of a difference between it and the MF to matter. if u do LT's then u can make a decision about your cats. not to sound like a broken record or anything.
Old Jun 28, 2004 | 03:17 PM
Do a search. It does.
Old Jun 28, 2004 | 06:13 PM
ratio411's Avatar
Gutted cats are worth about 5hp from what gets posted about them.
Also, folks that do it complain that gutted cats make more 'dirty' noise than an ORP. Empty chambers make for nasty noises apparently.
Magnaflow passes 1100 cfm flow.
Borla flows 900 cfm.
Hooker flows a little over 900.
The reason I throw Hooker out is because it is the only muffler that is said to sound good with an ORP.
Borla is one of the worst sounding with ORP.
Now, it stands to reason if an ORP rasps, and gutted cats sound worse, you would not want the Borla on there.
The good thing is you have plenty good pipes with the Borla, so you could just get a muffler like the Hooker and put on there alot cheaper than replacing the entire cat-back. Even with the free Magnaflow, I would just change the muffler if I went that route.
Just some food for thought.
Good luck
Dave
BTW: Send me the Magnaflow if you don't use it!
Old Jun 28, 2004 | 09:56 PM
NW Iowa WS6's Avatar
I don't personally think Rasp is all that bad....People think my exhaust sounds badass when it starts to kackle like a ****
Old Jun 28, 2004 | 10:14 PM
skippytheloon's Avatar
haha...are you sure that is not with the plate closed on the Borla? A closed off Borla is much quieter than most other exhausts and more restrictive partly because exhaust is exiting through just the longer bent pipe rather than the straight open pipe. I'm a newbie, but it seems that they probably tested the flow through those mufflers by themselves.
Old Jun 30, 2004 | 05:03 PM
ratio411's Avatar
I figure it was with the bypass closed.
Why would they test a muffler's flow only to have a cut-out open in front of it during testing?
That brings me to the question: Why buy a complete exhaust with a cut-out built in to make flow? Just put a cut-out on the stock exhaust for a fraction of the money... Assuming you like the sound of a cut-out. IMO they sound like ***.
Dave
Old Jun 30, 2004 | 05:19 PM
davered00ss's Avatar
Moderator
Keep the Borla.
