FAST 92MM Intake on a 2002 SS Camaro
Good afternoon gang-
I'm in desperate need of some help. I just finished swapping over my FAST Intake & my NW92MM Throttle Body, and I have one connector that seems to be out of place.
I have double checked the connectors in the back of the Intake, which is there is one on the Drivers Side, I verified that the connector in the very back, next to the Power Brake Booster Vacuum Line was hooked up. I also verified that the connector for the Fuel Line Evap was hooked up. This connector is on the Drivers Side, right next to the Fuel Injectors, as you can see in the Picture.
Does anyone know where it goes? It's not long enough to reach to the back of the Intake Manifold.... It only has about a 3" Radius where it can go, but I'm not finding it's proper "home".... Ha Ha!!
Thanks in Advance for ALL the Help!!
