VSS output from PCM
I'm using an LS1 and Tremec TKO 600 in a Cobra kit car. I have no experience of efi or PCM's. The aftermarket speedo I have will take a variety of input signals so can anyone please tell me what the VSS output signal is from the standard GM PCM?
Thanks....
Stan
I also want to make sure that what ever I connect to the PCM does not cause any damage.
On the 1999-2001 camaro pcm the trans inputs to the pcm are red connector pin 20 low vss signal pin 21 high vss signal and output from pcm to speedo is red connector pin 50.
Thank You all in advance for your assistance.
John
John
1: to the VSS wire from the PCM
2. TO my Speedometer.
