Ported truck intake?
Old May 5, 2017 | 08:08 AM
1970 Nova LSX's Avatar
Thumbs up Ported truck intake?
Hello,
I have a truck intake, any benefits of porting it? Whats the biggest throttle body that you can fit on those?
Can those intakes accept bigger injectors?
Thanks,
Jay
Old May 5, 2017 | 08:34 AM
KCS's Avatar
KCS
Moderator
Moving to Externals section
Old May 5, 2017 | 08:44 AM
Ok, sorry.
Old May 5, 2017 | 12:02 PM
omc8's Avatar
Well which truck intake do you have ? There are 3 different types..... old style 3 bolt , NNBS 4 bolt and L92 style.
Old May 5, 2017 | 01:01 PM
3 bolt throttle body of a 2004 truck.
Old May 5, 2017 | 01:35 PM
omc8's Avatar
Yes that intake can be ported and improved . Do you have good fab skills and tools ? Are you open to using another oem truck intake ? Or set on using this only. 5.3 or 6.0
Old May 5, 2017 | 01:44 PM
Its a 5.3. I'm not dead set on this one. Just figured I'd see what I could do with this one since I already had it. But I was looking and like the BBK and the LS6 intakes are around the 300 dollar range, so i figured if I could do something with this one, I would.
Old May 5, 2017 | 01:50 PM
omc8's Avatar
Im not suggesting you switch to a car intake . The truck platform is good if you have the hood clearance.
Old May 5, 2017 | 01:54 PM
Yes, its going in my 70 Nova, I kind of wanted something that looked a little better like the Holley Mid rise.
Old May 5, 2017 | 01:57 PM
omc8's Avatar
What heads oem 706/862 or aftermarket ? Its best to do as a combo. I can tell you how to do a full port on the intake if you like .
Old May 5, 2017 | 02:01 PM
That would be great! They are 862 heads, im looking for 243/799's.
Old May 5, 2017 | 02:23 PM
omc8's Avatar
Ported 862 or 243 would be good . Ok here is the mild version, you can open the tb snout up . Stock its only 74 mm you can take it 78mm its a long log or barrel about 7" long then the roof opens up. Concentrate your work here .
Old May 5, 2017 | 03:11 PM
omc8's Avatar
You can also clean the runners up . But if your not running cnc heads ,its best just leave the runners alone . Stock width is 1" don't go bigger than this. A full ported truck intake will out perform a LS6 intake.
