LS1 DS head grounds
I am trying to diagnose what appears to be an electrical/sensor issue. I read somewhere that putting all 3 grounds in one spot on the back of the driver head can lead to issues. I was lazy and did this. Does anyone know which two wires should ground together and what one is solo?
Thanks in advance
Did you put on new intake manifold gaskets when you put in the new knock sensors, and did you follow the correct torquing procedure
