2000 WS6 - Oil leak from balancer?
Old Jul 16, 2017 | 10:40 AM
camar0rs's Avatar
Question 2000 WS6 - Oil leak from balancer?
Anyone else have this happen?
This 2000 ws6 has an ls2 motor and you can see from picture it is leaking from the balancer.. this picture was taken AFTER the balancer was replaced and driven for like 20 miles...
The seal bad or ?
This was replaced by a shop and currently car is there still being looked into
IF the car sits and is just running at idle, appears no leak, only after driving... also car has not been driven past 50mph since gears also were just replaced recently...
Old Jul 16, 2017 | 06:45 PM
It LOOKS like the oil is below the lower edge of the timing cover, in which case I would suspect the cover gasket, or the front of the oil pan gasket. Strictly going by your pic...
Old Jul 16, 2017 | 06:57 PM
camar0rs's Avatar
i didnt get a better picture in looking up but you can see the oil from around the balancer going into cover
Old Jul 16, 2017 | 07:08 PM
handyandy496's Avatar
Should have replace the gasket with a new balancer.
Old Jul 16, 2017 | 07:50 PM
Darth_V8r's Avatar
Moderator
That's your front main seal OP. Whoever did the damper should have noticed the seal and called you up to ask if you wanted it replaced also.
Old Jul 16, 2017 | 07:59 PM
camar0rs's Avatar
yes everything was replaced
timing cover gasket
balancer
and whatever other seals
Old Jul 16, 2017 | 10:05 PM
A.R. Shale Targa's Avatar
Had this same leak after doing a cam swap
I made the mistake of just bolting the timing cover back on
Without dropping the pan and installing the balancer to center
The seal/cover "PRIOR" to tightening the cover bolts.
The pan pushes up on the cover causing the seal to wear out on the
Bottom and then leak past the balancer. Like yours, not at idle but
After driving
Old Jul 17, 2017 | 07:25 AM
camar0rs's Avatar
After driving
Makes sense what you are saying.... they did not drop the pan i know that...
So the correct steps would be then:
1) drop pan
2) realign timing cover to center balancer (probably have to replace the seal again here ?)
3) tighten cover
4) tighten pan
Old Jul 17, 2017 | 09:58 AM
Darth_V8r's Avatar
Moderator
timing cover gasket
balancer
After driving
1) drop pan
3) tighten cover
4) tighten pan
Somehow, I missed that the cover had come off. When you put the cover back on, there's an alignment tool - one that I did NOT use the first time, and I never got it to quit leaking.
You can save yourself having to drop the oil pan (trust me, you REALLY don't want to do that if you can avoid it) with the "align-it" tool from sac city vettes. It's like $40, but worth it not to drop the pan. You set the cover in place with the tool, then use the tool to press in the new seal. Bang
Old Jul 17, 2017 | 10:50 PM
07NBSChevy's Avatar
If all seals were replaced, I would suspect improper timing cover alignment. The shop should have used an alignment tool for the front cover, they can be very finicky. Like mentioned above, Sac City Covette sells this tool along with other alignment tools if you ever decided to do this. I have 2 sets of their complete alignment tools at my shop, they make these cover installs a breeze.
Old Jul 17, 2017 | 10:52 PM
camar0rs's Avatar
I called the shop again today and they did say they used an alignment tool.... its been there 3 days again, tomorrow day 4....
prior they were just running for 15 mins at idle with no leak but as i told them i saw leak after running it....
