146020COR for LS1 injector? Seems loose....
Hey Guys, I've seen a few posts stating to use the 146020COR for the fast LSX intake for LS1 style injectors, but I want to make sure I have the right part here.
I'm using a http://www.racetronix.com/621031.html That worked with my old FAST 90 setup and the current o-ring inside diameter is kind of snug around the injector. The new 146020COR is significantly larger on the inside diameter and seems excessively loose.
My setup will be LS2 rails with the FAST 102 LS3 intake and these injectors mentioned above.
Thanks in advance guys
