which intake for 4.8 build
I am in the process of building a 4.8 cammed for midrange power with 6k redline, prc stage 2.5 heads,36# injectors, built 4160e, factory 3:42 gears all in 86 Camaro.
I'm stuck with choosing the factory 4.8 truck intake vs ls6 intake vs fast intake. Which intake would be best for application?
I also plan to get a 6.0 shortblock later on down the line and swap everything over ....
Yeah, all cathedral truck intakes for a certain year are the same functionally.
LS1Tech Premium Sponsor
The tbss intakes use a 4 bolt 87mm tb. If you have a cable tb youll need a bigger tb and to fashion a cable bracket setup. It also doesnt have provisions for a return so that would need to be addressed also.
It all depends on what you have to begin with.
If you have drive by wire you would still need the 4 bolt tb and the torq rush throttle body adapter...and accomodations in the tune.
I have a dbw throttle body on my 4.8. I think I will leave the intake, just have to find out how to get it under my 86 camaro hood..
The link is here https://www.google.com/amp/www.hotrod.com/articles/20-ls1-intake-manifolds-tested/amp/
