LSX Intake & TB - Surge/Idling Issues ?
I haven't had a chance to have it re-tuned but is this really a tuning issue ? Is it possible the IAC is bad (car only has 9000 miles on it) ? When I installed the TB I verified that the blade completely closes so any ideas would be appreciated.
Thanks....
Here's a list of the setup:
A4
AS Stage 1x 5.7ltr Heads milled .030
TR224 563 on a 114
Nate's Billet Fuel Rails
Stock Injectors
78mm LSX Intake
78mm LSX TB
Check this post out. Mine was doing that too. 90mm TB and LSX intake.
Check these mechanical things first for binding or that loose bearing. Then check your IAC counts and yes check for vacuum leaks. After all that then get her tuned.
Dustin Butts : I'll check the mechanical and the reading on the IAC, a big thanks for posting the link and excellent write-up. I'll post back my results tomorrow.
Andy
Before LSX Intake/TB:
range is 22-30
After LSX Intake/TB:
range is 89-95
So whats causing the counts to read higher ?
Before my cam install, on cold starts, it wouldn't surge at all, however, it would choke down like it was going to stop running when I'd pull out ... only for about 5 seconds, then, it would run fine.
I changed my fuel filter and injectors and it didn't seem to help much, if any at all ... for what it's worth. It would be nice to know what this is. Think it would help to drill out the throttle plate a little bigger than the factory hole?
Thanks Ragtop for the explanation of high/low IAC counts, I searched and couldn't find an explanation...
JEB99TA, has your car ever been tuned via LS1edit ?
Since he changed whatever he changed and there was no difference, it doesn't seem to be a tuning problem. The !EGR and !AIR were both removed and disabled by the tuner.
