Help me plan my Top End Package
Old Oct 6, 2017 | 07:43 PM
  #101
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Regarding clutch choices, the McLoed RST certainly holds power but it is also a really heavy clutch....not ideal at all if your into speed shifting etc. and it will hurt dyno numbers and throttle response due to all the added heft (its a good bit heavier than stock)
I sell a nice lightweight single disc that's inexpensive and will hold up to 550 RWTQ....weighs about 42 lbs total (entire clutch and flywheel assembly).
Nate hit me up about that clutch via email or PM and we can discuss it in more detail. Save your money on head porting for the MMS 223's.....it's silly to invest money in the stock heads. Mill them and run them.....save that additional money for the MMS 223 purchase in your future (I got your email obviously!)
-Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Old Oct 6, 2017 | 08:23 PM
  #102
c5_nate's Avatar
-Tony
ha ha awesome thanks. Reply to it if you could (the cc’d gmail address would be better, the police one is work and I’m off for a week.) I’d like more info on the clutch, and if you have time, advice on milling and compression.
basiclly I would like to run as much compression as my shitty 91 octane will allow, but still be able to run an LLSR cam, although not sure which one as they have a few small differences.
Old Oct 6, 2017 | 09:05 PM
  #103
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
C5_Nate
You definitely made the right choice going with Tony & the MMS223,
I just had a 32 lb clutch & flywheel assembly installed from Tony
and love the quicker throttle response. You definitely want to go
Lighter rather then heavier lol, dropping 10 lbs with Tony's set up
is the way to go. If you ever change or rebuild the Diff, Eaton has
a limited slip with carbon fiber clutch packs that has a carrier
almost 6 lbs lighter then stock, it also comes with 300M
Left & Right output shafts which makes the whole package
a bargain I paid about $850 for it 4 years ago and just had it
Installed also. Review coming soon in the Dyno Results section.
Old Oct 7, 2017 | 05:35 PM
  #104
scotty2000ss's Avatar
-Tony
Pics of said clutch?
Old Oct 7, 2017 | 09:35 PM
  #105
LS1Tech Sponsor
Email me.....dont have any at the moment but will have a customer I just sent one to grab some pics and forward them to you.
It's a dual friction style single disc which works well at holding power without alot of clamp load at the pressure plate (which makes the left pedal a little heavier).
It's made with Luk components btw.....these guys have been building clutches a long time
My email is mamomotorsports@yahoo.com
-Tony
__________________
Old Oct 11, 2017 | 08:55 AM
  #106
TrickFlowTech's Avatar
LS1Tech Sponsor
Originally Posted by NAVYBLUE210
C5_Nate
That's cool about the Eaton Diff. Looking forward to the results. I didn't know it was that light. If mine goes out, I'll look into it. My RXT combined clutch/flywheel was 45lbs...down about 5 from stock.
__________________
Old Nov 5, 2017 | 07:38 PM
  #107
chetly's Avatar
This is some great information. Im looking at doing something similar with my 2004 C5z. Im interested in if a ported FAST 90/LS2 throttle body would be capable of performing with the Mamo heads and spin to 7000rpm or is the 102 a must? The car is strictly an autocross car that is trailered to events so I'm not against running higher compression for some punch off the corners and thats why i was thinking the 90/90 combo.
Picture of the car for ***** and giggles...
Speaking of clutches, I have a McLeod Street Twin with a Fidanza aluminum flywheel and the combo weighs 31lbs.
