Why 6.0s are so thirsty?
In OUR engines the best safety factor we can use is low temperature. Cold fuel, cold air, water injection, stuff that will slow the rate of combustion down so it doesn't get violent.
So what you are seeing in old gasoline allowed access to the atmosphere is, the lighter chains will evaporate first, and the heavier chains tend to stay behind and interact with each other, and form conglomerates. What I am trying to delivery is the message that "charcoal" and "gasoline" are 'dirty' with a wide range of carbon chain assortments, it is un-reacted portions of carbon chains that become "carbon deposits" in an engine.
The solution is to fully seal any gasoline that won't be used soon. i.e. tool maintenance. A carb is difficult to seal so we usually "run it out of gas" when done using the machine. I do this to every tool, 4-wheeler, boat engine, lawn mower; you don't leave the gas exposed to air in your beloved motor.
If you form varnishes, it isn't the fuels fault you let it exposed to air for too long.
if it has good filters and uses good gas, doesn't let it sit for long time between uses, it should stay clean as clean.
You would not believe the crud that built up inside a 10yr old engine. I'm talking about sludge so thick in the oil pan that a putty knife was a regularly used tool. I saw many neglected engines that the sludge was so thick the oil couldn't drain back because the oil return holes were plugged. A high mileage motor back in those days was anything over 100,000 miles. I see engines now that have three times that and no buildup to speak of.
Maybe someone wants to read this and tell us what it says (I didnt read it but it resulted first when I googled "how much water does 10% ethanol hold")
https://www.bellperformance.com/blog...tion-Water-E10
If we want to keep water out, here are some solutions for keeping water out I can think of at random
1. wrap the engine or carb with a desiccant (you can put small engine/carb into plastic bags with separate desiccant)
2. Dry boxing, you heat a box to drive water from the air and that is where you are handling and pouring fuels and closing lids
3. Clean dryboxing, same thing as a dry box but with air filters so it functions as a clean room for rebuilding carbs also
4. enter your imaginary way
The inside of some carbs might not really care about whatever water finds the fuel, though. keeping the fuel tanks of equipment full all the time to displace "air water" is far more hazardous and unpredictable when the tanks are "leaky and old" conditions. So it is situational, no "one correct way".
Back on topic, I’m assuming you are aware that you can “wash” modern gasoline to remove the alcohol content. If not, there are multiple how-to’s spread across the Internet, just hit your favorite search engine. This assumes also, that non-alcohol, “pure” gasoline fuel is not available in your area. I’m in the south central part of the country, and non-alcohol fuel is available pretty much everywhere excluding large cities/population centers.
The tetraethyl lead is possibly a different story. Any chance either you, or your father are chemist?
Wikipedia has a pretty good write up here:
https://en.wikipedia.org/wiki/Tetraethyllead
To include plenty of chemical formula’s.
OTOH, if a sealed 5 gallon bucket of tetraethyl lead magically appeared on your front door step tomorrow, do you have any idea how much you might need to add to restore your “now washed”, alcohol free gasoline to all of its 1960’s glory? I know I don’t. Also, wondering out loud if a 5 gallon bucket of tetraethyl lead would need any special handling instruction, or if filtered air mask would be necessary? I don’t know.
I’ve taken this restoration of leaded fuel around the long way intentionally. I have serious doubts, even with all the magic he has, that even President Trump could bring back the old leaded fuel we all knew and loved from the late 1960’s and early 1970’s.
If a 5-gal bucket of tetra lead showed up on my doorstep I'd report it to the proper authorities.
BUT if it showed up on my NEIGHBOR'S door, HE might mix it 2-2.2 grams per gallon if HE wanted to be around 100 octane. But he's far less responsible than most of us on this site.
He would probably wear polypropylene gloves and goggles or a face shield while handling it, because he is pretty careful about his personal safety.
