Why 6.0s are so thirsty?
4 door 4x4 with just a hyperjunk tuner
https://youtu.be/Sr5yFMN4gNw
LQ block with stock bore but 4 inch crank
Stock truck intake
243 heads untouched with Ls6 springs
Long tube headers (nothing big)
Small cam such as a 210/216
I know stroke eats duration... so I'm thinking a 210 cam in a 402ci would be the same as a factory cam in a 364ci motor.
Someone mentioned the 6-speed auto -- i've never driven one, but I can imaging how much better that is assuming they addressed the huge 1-2 drop in the 60E
what camshaft would you look for and acquire, how would this happen
TSP Stg3 low lift
TSP Stg3 high lift
Ill try to get an actual overlay to show the diff.
Thats not even full tuned amd wrung out either with a richer afr than most would run.
Then, dont forget mostly on the intake side. so like 228/220
This is the TSP 220r
Exactly what you're asking about. Note the torque peak. The higher duration you go normally moves peak power up so to speak and isnt made for towing. Even trying to use a more narrow lsa youll increase overlap and do the same thing.
Thats it. All together that load was just shy of 21k lbs. hauled it 5 hours one way. The tires made a HUGE diff. Some very nice 10ply Continental hwy tires. Got it up to 75 on the interstate also. Lots of hills too. No issues and ac on the whole time.
I have an all steel car hauler also i use for many chores besides just hauling cars around as well.
Im no hot shot or expert by any means, but ive been doing it so long i can tell you the capabilities of em.
Both will be getting 370s likely with some other upgrades soon. The 5spd manual is by far the best for heavy loads but the single cab sucks for it so its a trade off. That gooseneck trailer alone weighs ALOT.
TSP Stg3 low lift
TSP Stg3 high lift
