Modded Engine Spark Plugs
Old Jun 4, 2018 | 01:21 PM
Mystic98Z's Avatar
I got the drivers side done so far. One of my MSD 8.5 wire boots is touching a header. Does anyone know if I can bend these boots? I wasn’t planning on reusing the factory heat shields but may slide this one up if I can get the boot off the header.
Old Jun 7, 2018 | 01:59 PM
00pooterSS's Avatar
Even GM updated the gap from .060 to .040 on the trucks.
If you had a bad experience with NGK then something was off, I have been using them 20 years and I have never had a single problem with them. Delco and Denso make great plugs too. I've had issues with every other brand at some point. I've been a tech for 20 years so I put lots of plugs in lots of cars...
I would run a tr55 at .040-.045 if it were mine
And to be honest, it would be fine if you ran anywhere from .040 to .060
Larger gap tends to help a little with idle smoothness, but I gap at .040 - .050 with LS motors depending on the needs of that vehicle/customer. If it's big power and boosted then close the gap a little more.
