Modded Engine Spark Plugs
Old Oct 9, 2017 | 08:25 AM
Mystic98Z's Avatar
Default Modded Engine Spark Plugs
Just picked up an LS1 Z28 with the mods in signature. Car has been stored and driven very little for past 11 years. It runs good and was tuned years ago. I’m new to the LS1 scene but have only used AC Delco plugs in other GM vehicles. Other brands have given me issues. With the mods below, can someone suggest a good plug and gap setting? Going to pull a plug soon to see what’s in there.
Old Oct 9, 2017 | 04:18 PM
nine8ss's Avatar
I had this same question a couple years back. After reading numerous threads on plugs, I decided on NGK TR55s gapped @ .050 and never had any issues.
Old Oct 9, 2017 | 05:01 PM
Mystic98Z's Avatar
Great, thanks for the info. Those TR55’s do seem popular. Are those the iridium or just copper? I’ve always ran regular old AC Delco plugs with good results but I think I’ll give the TR55’s a try.
Old Oct 10, 2017 | 07:24 AM
redbird555's Avatar
Tr5 or tr55 is a copper plug
Old Oct 10, 2017 | 07:33 AM
HCI2000SS's Avatar
If it were me I'd go a step colder and go with a TR6. You are right at that threshold for a colder plug, and going with something like a TR6 will give you more of a cushion. That's just my opinion
Old Oct 10, 2017 | 08:05 AM
Mystic98Z's Avatar
After doing a ton of reading and research, I have been leaning towards the TR6’s. I’ve been weary of NGK plugs since putting them in an 04 GMC 5.3 and it ran like crap. Put AC’s in and it ran like a champ. I’ll probably go with the TR6’s and do some MSD wires while I’m at it.
Old Oct 10, 2017 | 08:19 AM
HCI2000SS's Avatar
Maybe on your old 5.3 set up the TR6 was not the best choice, but it definitely is the preferred plug on what you have now. Literally 100's setups similar to yours run this plug with great success. With the mods in my signature, I used to run them before I went with nitrous, and they worked great. You probably would be fine with the TR5 as well, but you don't have quite the safety net as you do with the TR6, so that makes it a wiser choice IMO
Old Oct 10, 2017 | 08:40 AM
KCS's Avatar
KCS
Moderator
Personally, I'd run a stock heat range plug, but if it's already tuned and run without issues, just keep whatever plug is already in it.
Old Oct 10, 2017 | 09:06 AM
Mystic98Z's Avatar
I think I’ll give the TR6’s a try. Gap at .045 ?
Old Oct 10, 2017 | 05:44 PM
allblackedout5's Avatar
TR6's for that combo will be best choice in my opinion.
Old Oct 11, 2017 | 06:06 AM
Mystic98Z's Avatar
Thank for the help guys! Going with TR6’s.
Old Dec 24, 2017 | 12:34 PM
Mystic98Z's Avatar
What should I be setting the gap at on these TR6 plugs?
Old Dec 24, 2017 | 01:16 PM
.045” should be fine.
Old Dec 24, 2017 | 01:21 PM
Mystic98Z's Avatar
Ok, thank you!
Old May 15, 2018 | 05:15 PM
Mystic98Z's Avatar
Finally got around to pulling plugs. They are Ac Delco 41-974 gapped at .060
The car was tuned with these. Will swapping to NGK Tr-55’s gapped at .045-.050 effect anything?
Old May 16, 2018 | 10:16 AM
rednari2's Avatar
A little insight on spark plugs. The larger gaps (.60 for instance) are harder on the coils. The coil has to wind up a nano second longer to jump the bigger gap. The current coils are about 25K volts. The older coils and truck coils are/were about 31k. The drop to .40 is because of the drop in voltage. Fifty is OK, but is a little harder on an OE 25K coil.
Second, I have used Autolite plugs in all my vehicles for decades. The AR 103 is a great racing plug. For your application I would recommend 5245s in standard heat range or 5243s if you want a colder plug. These plugs are available as standard copper, single platinum tip (center electrode), double platinum tip, or iridium under the above heat range numbers. Remember, for Autolite, Champion, and AC plugs, the higher number indicates heat range increase while the lower number indicates a cooler plug, which is the opposite of Asian NGKs.
Old May 16, 2018 | 11:36 AM
Mystic98Z's Avatar
So would you recommend a .050 gap? I’ll have to look in to the Auto Lite’s but the NGK’s seem to be quite popular here for the LS1.
Old May 16, 2018 | 01:32 PM
LilJayV10's Avatar
IIRC GM put out a TSB saying to gap them at .045 instead of .060
If you go with the stock heat range I'd get the TR5's because they can be gapped smaller. You can use the TR55's but they are designed for the larger gap and you have to bend the electrode down quite a bit to get to .045.
If you decide to go with the TR6's you won't have any problems.
Old May 16, 2018 | 03:41 PM
black sky's Avatar
definitely agree. You at at the crossroads between a TR55 and a TR6. I would lean towards the colder plug as well. .045 gap is a good number.
Old May 16, 2018 | 11:06 PM
rednari2's Avatar
Yes. The OE coils (25 K volt) can handle that. At .60 you need a truck coil to jump that gap safely. Also, I am not sold on the NGK or Accel V and U grooves. Its a marketing strategy with little if any increase in performance. The AR 103s are cut back plugs which offer a larger flame kernel and are cooler which are good for FI or NO motors, but not necessary for you.
