How much spray and how much whp
Last edited by 98Bluebirdls1; Oct 23, 2017 at 11:38 PM. Reason: forgot to put my block was rehoned
What did you gap your rings at?
Those two things will have a lot to do with how big of hit you can/should run.
Are you using a nozzle, plate or direct port?
Another thing is if you are using a progressive controller or just one shot.
Obviously you want to run a colder non projected plug like a BR7.
2 very important things are
1. Learn how to read spark plugs
2. Don't run a rich AFR on the spray. I see people all the time say keep it rich keep it rich, rich is safe. That's old school mentality that's not true and not safe. Whatever AFR the engine makes peak/safe power at NA is, it should be the same on the juice.
The tune part, for N/A is the easy part, "generally 12.7-13.0 AFR and around 26-28 degrees of timing" for a GEN III engine. Again I said, generally. Each engine will be different and likes what it likes, kinda like a woman.
Depending on how good your converter and port work is, and if you are pulling it locked/unlocked. On a honest dyno I'd expect around 400.
I spray 150 through a single nozzle. Plugs look good, afr is good, car pulls harrrrdd.
