IAT Sensor Location
it is advisable to put the IAT sensor near the same location in the intake tract as it would have been in a stock vehicle if possible. using a fast-acting thermistor is also advisable to avoid the affects of a heat-soaked sensor.
with a custom setup that does not mimick the stock routing, and especially in your case where you are dealing with an engine swap, trying to place it in an ideal location is out the window.
so my advice is to get a good tuner or tune it very well yourself, moreso than trying to find the ideal location. just make sure the IAT sensor is in the airflow, and do not place it around any bends. if it does end up in a bend, try to place it on the outside radius.
as for heatsoak with the s10/blazer intake, it's pretty unavoidable. with the radiator hose, as well as hot air being blown from the radiator right onto the intake. insulating the intake tract as much as possible, using a heat shield, and rerouting the intake are all advisable. you seem to have taken a lot of these steps.
