Who to port Msd intake?
Typically a 10-20 hp change could net you over a tenth depending on how fast your car is already and assuming they are similar days with a decent pass.
Now for me I've made quite a few changes since the first time i went 11.1@124.x with a ls6 intake to basically only net me a .2 gain in the end. But the car has picked up a solid 5-6mph in trap speed with only a 18hp at peak gain. Under the curve is where it's at. It's probably picked up over 30wtq in places. The 124 was on a 10bolt to now i have a 9". Best mph was on a 10bolt @ 131.3. Best on the 9" is 130.6. So sometimes there is some give and take......but I'm not fixing a broke 10bolt.
This is a good read for anyone considering port work on an MSD (or a FAST for that matter)
While it hits mainly on my work revolving around the MSD LS7 unit, the points made in the information below are all still applicable to other manifolds as well
A "ported intake" all sounds the same on paper no matter who puts a grinder to it but in the real world the difference in performance can and will be quite dramatic considering the varying level of background and experience the guy wielding the grinder brings to the table.
You get what you pay for in life.....the guys that make the most power on this board (and others) have already figured that out.
https://www.corvetteforum.com/forums...t-mamo-vs.html
Cheers,
Tony
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Mamo
o
m
o
Channel that Mamo power through a Momo steering wheel. It's a win/win.
MOM-2401
RCE35BK1B
