Ls2 build
Old Nov 27, 2017 | 05:11 PM
Brandon Andalon's Avatar
Default Ls2 build
Hey guys I'm Brandon I'm 20 and I built a ls2 to put in my Scion FR-S the swap is almost done and I'm hoping for 500whp wondering if that's doable with what I have
mod list is
iron block ls2 decked and honed
micro polished crank
custom Cbm cam 581.
Clevite h bearings
arp head studs
cnc ported 317 heads
dual titanium springs
Over sized titanium intake and exhaust valves
brass valve guides
comp trunion upgrade kit
66lb injectors
billet fuel rails
92mm tb
hi rise sheet metal manifold from fi tech
Aeromotive a1000 fuel pump
custom cx racing 1" 3/4 headers
it's going to be on e85 gas
running fi tech stand alone. 🤔
Old Nov 27, 2017 | 05:23 PM
Do you know your cam specs?
Old Nov 27, 2017 | 05:25 PM
HCI2000SS's Avatar
LS2 iron block??
Old Nov 27, 2017 | 05:45 PM
Brandon A, your engine is either an LQ4 or LQ9.... no such thing as an iron block LS2, which are all aluminum blocks.
Old Nov 27, 2017 | 09:08 PM
brandon6.0's Avatar
Not gonna happin. More like 450rwhp. 500 is a hard mark to get to with sbe setups. Takes alot of thought and know how.
Old Nov 28, 2017 | 05:00 AM
Tuskyz28's Avatar
Need better heads.
Old Nov 28, 2017 | 12:54 PM
98znasty's Avatar
Cam specs? Compression? Who ported the heads? I'm thinking under 450 to the wheels.
Old Nov 28, 2017 | 01:07 PM
98znasty's Avatar
Going turbo?
