Oil pressure and oil temp for ECU??
So im almost done wiring up my LS6 harness with F Body ECU
I have hooked up coolant temp sensor but i dont even see a pinout for engine oil temp and pressure.
1. is this necessary for ECU functionality? If so, which pins do these need to go into??
2. I will be running Speed hut gauges in the dash with its own sensors and wiring. i do not need OEM sensor reading if not required by ECU
If the ECM has a PID for oil temp, it's calculated, so no sensor.
as far as the oil pressure sensor, on the GTO ECM (which is what i have the wiring diagram for) there is a pin for the oil pressure sensor. Not sure about older ECM's.
