02 intake removal
Old Feb 26, 2018 | 07:21 PM
johnfin's Avatar
Default 02 intake removal
Do I have to remove the automatic dipstick tube to remove the intake manifold. If so, 1.will fluid come pouring out if removed and 2. if removed can I drive the car off the ramps. I would like to remove the intake while the car is on the ground.
Old Feb 26, 2018 | 07:24 PM
98CayenneT/A's Avatar
You do not need to remove the trans dipstick to remove the intake. If you ever did remove the dipstick tube transmission fluid will not pour out. The fluid lever is at about the top of the pan where it meets the case.
Old Feb 27, 2018 | 09:30 AM
johnfin's Avatar
Default Reason
Have you done a replacement. Factory manual says remove it.
Old Feb 27, 2018 | 09:51 AM
King Nothing's Avatar
I can’t count the times I’ve pulled and reinstalled my intake manifold and I’ve never removed my trans tube. You don’t need to at all. The manual says to do things a certain way and even dealers don’t do it that way, but they will charge you for it because the bill by the book.
Old Feb 27, 2018 | 10:00 AM
I have done many.
Old Feb 27, 2018 | 12:22 PM
johnfin's Avatar
Default Tube
Did you relocate your tube. Mine is more over the intake. Yours looks like its over the rocker cover
Old Feb 27, 2018 | 12:32 PM
No, I posted that to show I have had my intake off since you were kinda questioning me. That is a MSD 102 intake.
The transmission dipstick tube does not need to be removed to remove the intake. You can get to all the intake bolts and once loose the intake only needs to be lifted up maybe 1/4 - 1/2 in. and pulled straight out.
Biggest thing to watch out for is disconnect the break booster vacuum line so you don't break the oil pressure sensor on the top of the back of the block
Old Feb 27, 2018 | 01:05 PM
I have had my intake off many times with it like this in the picture before the msd. I had it off 3 times in one day chasing a vacuum leak once without touching the dipstick.
Old Feb 27, 2018 | 02:08 PM
bbond105's Avatar
It want hurt to bend it to the side a little if needed.
Old Feb 28, 2018 | 01:53 PM
feldz82's Avatar
I pulled my intake off this past weekend. I didn't touch the dipstick tube.
Old Mar 1, 2018 | 11:26 AM
ironmanLS1's Avatar
Best thing I do is take the bolt out holding the tube brace which allows a little movement and gives you a little more room to get fat hands back there.
Old Mar 1, 2018 | 12:04 PM
qweedqwag's Avatar
You have to remove it or the relative bearing grease will leak out,
Old Mar 4, 2018 | 05:56 PM
johnfin's Avatar
Good thing i bought a new sender unit. The previous idiot mechanic really screwed thing up. Broken sending unit, fuel injection connectors broken, pvc hoses broken, intake bolts loose. When you guys pull the intake, do you take the brake booster hose with it.
Old Mar 4, 2018 | 06:03 PM
Correct, first thing I would do is just pull the vacuum line out of the brake booster so you don't forget and brake the oil pressure sensor
Old Mar 5, 2018 | 09:28 AM
johnfin's Avatar
Can i remove the top valley pan without removing the knock sensors or do they screw into the lid. I would like to replace the seal.
Old Mar 5, 2018 | 09:33 AM
99Silver6.0's Avatar
Sensors gotta come out first before the cover will come off.
Old Mar 5, 2018 | 12:12 PM
johnfin's Avatar
Default Booster hose
Looks like the hose is above the sending unit
Attached Thumbnails 02 intake removal-10-ls3-swap-c5-corvette-ls1-cam-sensor-map.jpg
Old Mar 6, 2018 | 07:18 AM
johnfin's Avatar
Where does the knock sensor connector clip to?
Old Mar 6, 2018 | 07:39 AM
ddnspider's Avatar
You need to buy a Haynes manual or Google and you'll find the service manual.
Old Mar 6, 2018 | 08:02 AM
Older LS's had a taller oil sender. Thats the one that is fragile as hell.
