Pcv questions
Old Mar 3, 2018 | 09:50 PM
Dalton Barrett's Avatar
Default Pcv questions
I’ve been building my car for a year and just finishing it up. It’s a 98 camaro so came with the perimeter bolt valve covers. I went with 243 heads, so Can anyone give me some ideas for pcv routing? Preferably without buying the ls6 valley cover but if it’s necessary i can buy it also. Thanks in advance
Old Mar 3, 2018 | 10:12 PM
98CayenneT/A's Avatar
I run the rear drivers side port to the clean air on the throttle body then the front passenger side to a catch can ( air compressor dryer/ oil separator $15) then to a pcv valve and then to the intake.
Old Mar 4, 2018 | 12:47 PM
what kinda catch can did you use? And did you use the stock pcv system still?
Old Mar 4, 2018 | 04:51 PM
What valve covers are you going to run ?
I use an air compressor filter/oil separator as a catch can.
https://www.google.com/search?q=air+...UEcBT4QgTYIjQM
Old Mar 4, 2018 | 06:19 PM
I’m gonna run a factory 99-02 set. Is there any difference between the year models?
Old Mar 4, 2018 | 06:36 PM
Nope, all 99 - 02 are all center bolts and the same valve cover
Old Mar 6, 2018 | 05:56 AM
what kinda hose did you run for yours? Will 3/8 fuel hose work or do I need to use something different?
Old Mar 6, 2018 | 11:55 AM
Chris Paveglio's Avatar
Vacuum hose is technically different from fuel hose. I read that it comes in "only /16ths" sizes. And of course is more rigid to withstand collapsing vs internally pressured like fuel. But it probably doesn't make much of a functional difference unless you have a really really high vacuum.
