Starter solenoid positive stud loose when cable removed - abnormal?
Wondering if this is normal, anyone have a bench starter/solenoid laying around they can look at? Trying to see if I need a new one, it does have sporadic starting issues but I thought it was because my battery is in the rear.
I was pulling the positive cable off of the starter and noticed the stud itself is loose, like I can wobble it from side to side while still being attached to the starter/solenoid
Thanks,
Thanks,
Hey man, and thanks for the reply!
Are you saying there should be a nut that holds the stud down, and then my battery connection, and then another nut? Or just the one nut. just making sure
Also it is tight again once I tighten the connection nut back down, but just making sure nothing is broken.
Also it is tight again once I tighten the connection and nut back down, but just making sure nothing is broken.
If it stays tight when the cable is tightened then you may be okay. I would leave it alone only if you are able to find a wiring issue when you troubleshoot your intermittent starting issue. If the wiring checks out, then you may need a new starter, if you own the car long enough, it's an inevitability and it's not too expensive or difficult to install.
So yes, a wobbling stud (hehehe) is abby someone.
You can just take the nut you have, determine the threads (8mm "std" whatever that pitch is I think but I could be misshapen), pick one up at Lowe's or some such. Try to find a thin one.
Thanks,
