Oil Cooler Line Size
Old May 2, 2018 | 10:02 AM
98GMT6.0LSX's Avatar
Default Oil Cooler Line Size
I am swapping a LQ9 6.0L into a 98 k1500 truck. I plan on making up my own lines for the oil cooler. The oil cooler itself is integrated into the stock 98 k1500 radiator. Question is I have a Oil Cooler adapter and the fittings on it are -10AN. Would running -10AN lines be too big for the system or will it not effect the oil system at all. Thanks ahead for all info and advice.
Old May 2, 2018 | 10:57 AM
DietCoke's Avatar
-10 is pretty typical.
Old May 2, 2018 | 11:56 AM
Okay thanks.
Old May 5, 2018 | 02:02 PM
.boB's Avatar
IMO (which is free, and probably overpriced) -10 is minimum size for any external oil component.
Old May 6, 2018 | 08:34 AM
RB04Av's Avatar
Factory LQ9 lines are about ½"; pretty much equivalent to #8. (might actually be metric in some nearby size but w/e) So yes, #10 should be fine in most situations.
Old May 7, 2018 | 02:33 AM
S_M_I_D_D_Y's Avatar
-10 absolute minimum -12 even better. the hoses are fine but the inside of the fittings are quite abit more restrictive. you cant go "too big"
