Throttle bodies with idle bleed screw
Old May 6, 2018 | 09:34 PM
LsxS10blazer's Avatar
Default Throttle bodies with idle bleed screw
I was looking in to getting a better throttle body but before I do I wanted to get some feedback from people that have experience tuning if having a idle bleed screw really helps with the tuning and driveability as much as these companies state that they do? Most are pretty pricey but if it's worth it then I'm willing to save the money to get one. I tried to find this info by searching before posting but had no luck, thanks for the help and below is a link of an example throttle body that I'm looking at
https://www.holley.com/products/ls_power/ls_throttle_bodies/parts/112-589
Old May 7, 2018 | 11:20 AM
jaxcam02's Avatar
The most important thing is to find a throttle body that maintains the GM Idle Air Control Valve. I bought a holley throttle body that did not use the OEM IAC valve and I had to have it machined to accept it to get my tune working right. BOTH Holley IACs failed to work correctly and myself and the tuner spent weeks trying to trace the awful idle and we eventually figured it out. If the IAC functions correctly there should be no reason to adjust the bleeder screw a lot.
Old May 7, 2018 | 12:00 PM
Ok thanks, I'll keep that in mind while looking for one
Old May 8, 2018 | 06:35 AM
Trying to get a 6 liter idling correctly currently, with a new Holley 92. I’m glad you posted this.
Old May 8, 2018 | 09:49 PM
jaxcam02's Avatar
Take a stock throttle body, stock IAC and the Holley up to a machinist and get them to match the hope. The Holley IAC is such a piece of ****. Damn thing is made out of plastic and doesn't even operate smoothly. I love the Holley 92 and Doorman LS2 intake set up now that everything is working correctly.
Old May 10, 2018 | 11:39 PM
dreadpirateroberts's Avatar
Having an idle bleed screw on an LS throttle body using a P01 IAC ECM is probably not a good idea.
you want good tuning and drive-ability with an aftermarket throttle body, you need to learn how the ECM uses the idle air count vs effective area scheme.
Old May 10, 2018 | 11:46 PM
Ok thanks for the help, I'll stay away from those throttle bodies
Old May 11, 2018 | 07:09 AM
jaxcam02's Avatar
You don't necessarily HAVE to stay away from them. Just don't adjust the screw from wherever its set when its installed and the car is tuned. It just doesn't play a role in the overall airflow of these cars like the manufacturer want you to think.
Old May 11, 2018 | 07:25 AM
Ok, I understand. Ill probably just stick with warr or Nick Williams
Old May 12, 2018 | 05:24 PM
i wouldn't bother with it, personally. it's a waste of money and would tempt the unknowing user to fiddle with it after it was tuned, which could cause all sorts of issues.
Old Jan 21, 2020 | 09:33 PM
Notcammin's Avatar
So glad I read this before I actually ordered one from holley. Going to be visiting a machine shop soon. My apologies for bringing this back from a while ago.
Old Jan 25, 2020 | 10:33 AM
wannafbody's Avatar
One thing about the Holley 92 is that it's smaller than a Nick Williams 92. In fact face to face, the Holley fit inside the NW TB.
