Band clamps???
it is poor fit of Y-to-I outer-to-inner diameter.
The clamp is supposed to just keep things from
slipping, not crush the pipe (at least, that way
you can take the thing apart again!). There
should be a slit section at the end of the I, just
enough compliance to let the band squeeze
down. On a well matched pipe pair it should be
just shy of impossible to get the Y into the I,
meaning there will be negligible leakage. If
she's a sloppy 'ho then, well, maybe you need
to wrap it.
to wrap it.
connectors available that could be welded to
the pipe stubs (better than the usual reducers
w/ 3-bolt rings?) as-fitted, this would at least
allow you to take down the exhaust for other
work, etc. Or, maybe get some proper-fitting
tubing welded up so the band style sleeve-fit
works as meant.
RTV in the exhaust might poison your O2s and
is generally not recommended.
Seriously, give a Reese monkey an arc welder and a Meineke shirt and ask him what he thinks. You'll get a more coherent answer and probably higher quality work.
The clamps are indeed crappy, heard that many times - just thought I'd poke fun at the muffler shop.
Bad30th
This is sooo F*CKED UP, i'm speachless...i have no clue how to get this b/s squared away w/out puttin out more $$$....so much for "you get what you pay for" I feel like i just spent 200 bux on a catted ypipe
I bought some Thermo sheild from jegs. It's a high temp tape (about 2" wide) that I wrapped around the pipe connection twice then I put the band clamp over that and they havn't leaked yet. I have gone about 2000 miles since. Last edited by DUSTYWS6; Jul 6, 2004 at 07:09 PM. Reason: kant spell
I bought some Thermo sheild from jegs. It's a high temp tape (about 2" wide) that I wrapped around the pipe connection twice then I put the band clamp over that and they havn't leaked yet. I have gone about 2000 miles since.I used torctite (http://www.torcausa.com/) on some connections, torctite + aluminum foil on others, and traditional muffler clamps as well to stop the leaks. Good luck!
