Snapped flexplate bolt, would u ship it? Pic inside
Old Jun 21, 2018 | 01:53 PM
80/TA/LT1's Avatar
Default Snapped flexplate bolt, would u ship it? Pic inside
Well I'm ready to put my engine in and this happened. By the time I get a replacement bolt and IF I can get this one out, I'll be pretty far behind because of my schedule. I'm thinking of putting it together as is, anybody done this? Thoughts??? Thanks
Old Jun 21, 2018 | 03:57 PM
NO. You would always know, and it WILL bug you. Because you NEVER know.....
Old Jun 21, 2018 | 05:17 PM
99blkfrc99's Avatar
Send it
Old Jun 21, 2018 | 09:07 PM
brandon6.0's Avatar
I worked on my grandpa's kubota tractor and the flywheel bolt break off just like tht. I installed it back together with one broke. Been doin fine for over a year now.
Old Jun 21, 2018 | 09:54 PM
It would bug me, but maybe I'm just paranoid about crap like that.... Though a tractor that never sees north of 2500RPM is a hair different than an LS pumping out 400-600HP at 6000-7000 RPM. But that's just me....
Old Jun 21, 2018 | 10:35 PM
Burken01's Avatar
Using a faulty torque wrench?
Old Jun 22, 2018 | 04:35 AM
8.Lug's Avatar
This is why you don't reuse stock torque-to-yield bolts.
Old Jun 22, 2018 | 05:55 AM
Rob10CamaroSS's Avatar
My biggest concern would be will it be unbalanced ?
That and depending on the power level and how hard the transmission shifts could play a part on longevity. I had a high power 70 SS 454 Chevelle w/T400 that shifted so hard I cracked 3 brand new flywheels over the course of a couple of years. With big power and hard shifting you have a lot of rotational stress on those bolts, in a case like that I surly wouldn't want to be minus one.
On a mild or stock set up and moderate driving my guess is ya it would probably hold but nows the time to fix it, (or at least drill & tap it and put a smaller hardened bolt in)
Old Jun 22, 2018 | 08:47 AM
TheNutDriver's Avatar
Remove and replace FOR SURE.
Old Jun 22, 2018 | 08:54 AM
Zmg00camaross's Avatar
I bet it would be fine and cause no issues. But I would make a effort to try and extract it!
Old Jun 22, 2018 | 12:35 PM
80/TA/LT1's Avatar
Thx guys, I was able to get it out believe it or not, one less thing to worry about. I'll be using new bolts from now on, save myself some grief
Old Jun 27, 2018 | 01:03 PM
00pooterSS's Avatar
When bolts break like that they usually come out reallllly easily. It's when they are cross threaded or rusted solid and break that's a nightmare.
Get yourself a small kit of reverse drill bits, next time you have a bolt break just drill it with the reverse bit and the bit will run the bolt right out. Or you can use a pic or pocket screwdriver to grab a little piece of the bolt that's left and spin it round and round till it comes out.
Old Jul 2, 2018 | 04:09 PM
2001LSXZ28's Avatar
Take the time to go get the same size from a hardware store in a hardened bolt, and put all new ones back in with some blue loctite. It won't take that long. Don't chance anything with a project car! I couldn't if it were me....
Old Jul 5, 2018 | 06:19 AM
99Silver6.0's Avatar
Like mentioned above, get a reverse drill bit and extractor. As long as it went in easy it should come out fairly easy. Either the bit will spin it out as your drilling or the extractor will get it.
