Keyed 12 volt source??
Old Jul 7, 2018 | 08:11 PM
curtisad's Avatar
Default Keyed 12 volt source??
Can someone tell me where a convenient keyed 12 volt source is near the alternator?
Old Jul 8, 2018 | 11:57 AM
RB04Av's Avatar
How much power do you need? (what are you trying to run with it)
Old Jul 8, 2018 | 01:33 PM
curtisad's Avatar
It goes to a pigtail going to the alternator so that the check gauges light will go off. Probably minimal amps.
Old Jul 8, 2018 | 03:22 PM
RB04Av's Avatar
I doubt just jamming 12V into the alt somewhere will make the Gauges light happy.
Are you sure you don't need either the warning light connection, or the duty cycle output? Which alt do you have? What's its connector supposed to look like? How many wires are going to it? What vehicle?
Old Jul 8, 2018 | 06:11 PM
5.7stroker's Avatar
Most likely a Mechman alternator adaptor. I would just run it up from the alt to the fuse box or run it through the firewall and use a spade terminal on the fuse panel inside the car. I believe one of these wires is a constant on and the other is a keyed 12v source.
Old Jul 14, 2018 | 03:16 PM
curtisad's Avatar
I tried the alt battery terminal for grins and it turned off the check gauges light. Would it hurt anything to wire it permanently to the alt battery terminal?
Old Jul 14, 2018 | 05:38 PM
5.7stroker's Avatar
The wire going to alt comes direct from the battery and is a constant hot....
