TSP fast 92 intake/TB kit, thoughts?
https://www.texas-speed.com/p-3822-fast-lsx-92mm-black-intake-manifold-throttle-body-combo.aspx
243 heads
BTR stage 3 cam
1 3/4 inch speed & engineering LT's
tsp catback with built in cutout
LS6 oil pump portex
LS2 timing chain
3200 stall
Tranny cooler
Built 4l60e
3.23 gears
Ported and polished throttle body
SLP lid
Poly motor and transmission mounts
397whp through a mustang dyno
So you added a Fast 92 unported intake to your heads cam car and it only added 10WHP? I'd be interested in getting it ported, if that helps raise the number up to 15-20HP in that case. 10WHP just seems so low, that's barely more than an UDP. I believe you though, was hoping for at least 20, I'm sure I could feel an increase of 20HP before an after.
I've narrowed it down to a 92 intake and TB, ported 243 or other aftermarket heads, and a 25% UDP. I'm sure the heads will get me the biggest results, but they're the most expensive, and don't really want to tear into the engine again just for heads. If I'm only going to get 10WHP from a $1250 intake set, I think I might go heads and UDP then.
https://ls1tech.com/forums/dynamomet...got-heads.html
Would a 224/228 cam be a little more torquey? Yes, and honestly if you weren't gonna race the car ever including the street then that might be a better cam for part throttle driving or short burst but if you are going to be kicking it off from a roll and rowing through the gears then that bigger cam is what you want. Oh and the FAST 92 isn't going to cost you any torque. It will pick up everywhere.
I'm going to aim for 3k-7k with my C5, even though I know I'll trade off some peak power to get that range.
Unless paddle shifters suddenly become affordable. In that case, 5000-7000 should be plenty.
