2001 Zo6 issues
Old Sep 24, 2018 | 12:47 PM
z28_YOU_HO's Avatar
Default 2001 Zo6 issues
So looking at picking up a 01 zo6 with 92k miles...Seller says this
Has an electrical issue currently that causes it to shut down when it rolls over 5 mph. It does that almost every time, but sometimes will let you drive away. I think it's to do with the security system since the security light stays on
What could this be? Easy fix or is this an electrical nightmare i dont want any part of?
Old Sep 24, 2018 | 01:02 PM
Sounds like something that might be able to be tuned out. OR the speed sensor (VSS) is bad or has a bad connection.
Old Sep 24, 2018 | 01:59 PM
z28_YOU_HO's Avatar
I've been searching and have been reading that is could possibly be the steering wheel position sensor going bad????
Old Sep 24, 2018 | 02:02 PM
Yours sounds more speed-related, UNLESS it's doing it while turning the steering wheel, which still should not be an issue.
Old Sep 24, 2018 | 02:03 PM
z28_YOU_HO's Avatar
I found this
http://www.complianceparts.com/lmc5ataglance.html
Old Sep 24, 2018 | 02:10 PM
Originally Posted by z28_YOU_HO
Interesting! Didn't realize the C5 had this issue. You might want to ask around other C5 owners and feel this thing out. It could easily be legit, but I am always leery of a potential sales job.
Old Sep 24, 2018 | 02:17 PM
z28_YOU_HO's Avatar
Agreed. Also dont want to get into a car that i cant test drive. I could get it going and then it have other underlying issues like trans, clutch ect
Gamble i guess... Hmm
Old Sep 24, 2018 | 02:59 PM
Use all the above as an argument to hammer the price. NOTHING is unfixable IF the price is right.
Old Sep 25, 2018 | 04:20 PM
dreww's Avatar
I had this problem.....the one in the link. It had the recall/factory bypass already installed.
steering would lock...car wouldnt drive more than a couple mph .
I disconnected the factory bypass box and fixed it. Never happened again. I did buy the aftermarket bypass and installed it years later cause I was bored at work. Still no problems
