LS1 Intake with 92mm Throttle body ?s.
Thanks.
there's no benefit to swappin on a 92mm throttle body on a stock ls1 intake. None. If you want a little more power via a TB-related mod in the mean time, port the stock TB and half the throttle shaft.
Second, I would not waste my time or money with the LS1. A stock LS6 manifold will give you 10 or more ponies depending on the motor build. Just, but it on and use the 75 you already have. A used LS6 is about the same money as an 85mm TB and adapter kit.
1. You have tuning software to adjust your idle
2. You have a scanner to monitor your idle and IAC counts
3. You know how to use the set screw or are willing to drill a hole in the throttle body blade
My eBay TB required a small hole to be drilled, idled perfect after that and a tune.
I'll have to disagree with this. You should be able to get any throttle body dialed in easily with any cam as long as:
