Fast 92 vs 102
Old Oct 7, 2018 | 07:48 PM
youguessit's Avatar
Default Fast 92 vs 102
How much of a bottleneck is the fast 92 vs 102 on a big cube motor.... trying to hit over 500 rwhp... car is a 2002 camaro
Old Oct 7, 2018 | 07:58 PM
HCI2000SS's Avatar
Maybe about a 5-8 hp difference from what I've seen
Old Oct 7, 2018 | 08:01 PM
Firebirdmuscle's Avatar
I was also told about the same thing, 5-10 rwhp difference and this was on ported intakes
Old Oct 7, 2018 | 09:33 PM
youguessit's Avatar
Thanks for the replies
Old Oct 8, 2018 | 09:32 PM
99 Black Bird T/A's Avatar
FWIW - on my 383 LS1 with a 229/229 cam, the whp difference peak hp in a Fast 90/92 and a 102 LSXRT was 1 whp. And ~3-5 wtq this was on a chassis dyno same conditions etc. Not exactly an LSXR but in the ball park. With a bigger higher revving cam, I suspect the LSXRT would have been ~ 5whp to 10who better than the smaller intake. Neither intake was ported. The Fast 90/92 was better drive ability wise.
Old Oct 11, 2018 | 09:39 PM
wannafbody's Avatar
Thanks for being honest about your results. Too often hype takes over forums.
Old Oct 11, 2018 | 11:37 PM
HioSSilver's Avatar
I went from a fast 90 to a fast 102 and had next to no change with a bolt on ls6.
with that said the 102 is the nicer intake of the 2
Old Oct 12, 2018 | 08:15 AM
R6cowboy's Avatar
Did you notice any difference at all in drive ability between the two intakes?
I assume you ported both intakes?
Old Oct 12, 2018 | 08:40 AM
HioSSilver's Avatar
Both were ported and the 90mm tb offered no issues. The 102 was a ebay special so i did a little epoxing to make it drive like it should.
Old Oct 12, 2018 | 02:02 PM
z-maro's Avatar
Hio, how much do you port on the 102s? Do you just do the insides of the runners, or have you ever tried shaving the "ribs" off the outside of the runners such as in these threads?
https://www.corvetteforum.com/forums...g-results.html
https://ls1tech.com/forums/generatio...ts-inside.html
Old Oct 12, 2018 | 02:11 PM
Chris25's Avatar
The 102's dont have that much to port more just shaping the runners to the ports on the heads and doing a little work on the snout.
Old Oct 12, 2018 | 05:31 PM
HioSSilver's Avatar
i shaved the ones on my ls6 but never got around to seeing what it did before i hurt it.
Old Oct 14, 2018 | 03:33 PM
z-maro's Avatar
​​​​​​Oh, dang, it would be interesting to see what kind of difference it made. You hurt the FAST or the whole engine?
The references I posted were on the 102's where they shaved the ribs on the outsides of the runners. My Mamo ported 102 doesn't have the ribs shaves off so obviously Tony doesn't mess with doing it on his ported intakes. Just wondering if that's for time/money reasons, or if it doesn't provide much gain for all the trouble.
Old Oct 14, 2018 | 05:31 PM
HioSSilver's Avatar
I hurt the ls6. Did the dreaded $ shift while testing a load cell ignition cut.
Old Oct 14, 2018 | 05:40 PM
Chris25's Avatar
I know I was just saying out of the box there's not much to Port on a 102 I've seen the threads on shaving the ribs and epoxying them just seemed like there wouldn't be much return on investment when it comes to work.
Old Oct 14, 2018 | 06:38 PM
HioSSilver's Avatar
Idk....i take a fair amount out of 102s.
Old Oct 14, 2018 | 07:49 PM
Chris25's Avatar
I usually just straighten out the runners and port match the runner to the head and open the snout a little. Is there more to Port I need to take mine off again to paint it anyways?
Old Oct 14, 2018 | 09:07 PM
HioSSilver's Avatar
It just ends up being a fair amount of material that gets removed doing it like that.
Old Oct 15, 2018 | 08:26 AM
R6cowboy's Avatar
I seen a pic of how much material Mamo takes out porting a 102 and it seemed to be a lot.
Old Oct 15, 2018 | 09:50 AM
Chris25's Avatar
Yah just seemed like allot more is removed from the 90 and 92 with that stupid wedge you have to knock down.
