PCV valve vs check valve
The entire point of the pcv valve is just to prevent a backfire from entering the oil soaked areas (some called them flame arrestors back in the day). Back when cars ran breathers connected to the air filter housing it was common to have an oil soaked foam filter sitting a few inches from the carb. It was a risk, but none of the manufacturers felt that nervous about it. That said, if you intend on working it into the system then make sure you have it after the catch can or else a backfire can turn the catch can into a mini bomb.
Yes your correct,I meant to say the check valve (PCV) will be going from the catch can output side to the intake, brain is fried this morning. I've decided to go ahead with this 6AN one way check valve since I am running a catch can just to give it a shot. I have on hand a new and true PCV valve for an inline setup and after comparing the two there just doesn't seem to be a lot of difference when I blow through each of them. I know this is not very scientific and maybe I am missing something here but unless somebody can come up with a more specific reason not to give this a try I'm all in. Also too me this is what resto-modding is all about, finding out what can and can't be done. At the least, if there is a problem with idle or acceleration I'll know where to look. Attached is a diagram I just found that explains idle to acceleration during PCV better than I can. Thank you for your input! BTW, I remember those old car breather set ups as well, yes I am that old.
My main concern is oil deposits on the intake and intake runners due to blow by. I'm not setting this build up for street racing, just want to have a little fun now and then when I hit down on it.
It's actually been a few years since I last played with pcv swapping. I spent weeks finding a valve with similar dimensions and spring rate to stock but with the angle I wanted. Then I had to buy almost a dozen grommets to get something that fit the intake and new valve. In the end my Buick 455 had a pcv from a dodge and a grommet for a ford lol
I finished up the PCV system tonight with a one way valve in place of a true PCV and utilized a catch can on the dirty side (DS) along with a one way valve on the clean side. If this works my goal of having every hose in the engine bay be SS braided will be complete and be very clean looking under the hood. After a long five year frame off build I am just a week or two away from finally being able to fire this LS Gen III off. Getting anxious to hear it run....hopefully!
