TSP Duals vs Y Pipe/Catback for H/C/I 150 shot
Gained 5mph over using WHAT?
What did that replace? 5mph gain is a LOT.
I'm curious what you had prior to Mufflex/Flowmaster merge.
I have a mild 6.0 with just a set of 1-3/4" BBK longtubes and their included Y.
Turbo spec'd cam that it had, showed zero gain between full closed exhaust (Jeg's) and 3" cutout open, mounted in the "I" pipe under passenger side rear seat.
Now with better cam, there's an obvious power difference between the two.
Just trying to figure if I should "start over" exhaust wise?
I think they are 1.75" primaries to 3" collectors, then from flanges to 2.5" pipes to the "Y", then 3" from there.
I only chose it due to me feeling it was a better "Y" transition (dual 2.5's, to 3"), as opposed to most others, which are dual 3" to single 3"
Are you saying to just adapt a 4" merge to what I have?
Or swap to a 3" Y pipe?
I guess a new 3" Y pipe, merged into a 4", then mated to the rest of my 3" exhaust wouldn't be too bad to figure out.
My entire exhaust, from header gasket to exhaust tips is new, so this kinda sucks...
I know I had to "oval" near the "Y" part to clear my Spohn chassis mount torque arm crossmember.
I can't imagine trying to fit a 4" Y in that spot, but it does look like it's pretty flat (oval), where it would go between the crossmember and floorpan.
I wonder if I could/should cut the collector flanges off, and basically convert them to a slip on style, and simply use a different brand 3" pipe, to 4" merge?
The headers fit great, so I'd hate to also have to remove them and buy everything again...although it wouldn't be the first time...LOL
Found them on Summit...
I forgot about the flanged part of the headers, which really creates, at least looks like, a bad bottleneck.
Here's my thinking, someone please critique, if I'm thinking bass ackwards...
1.) Cut the flanges off of the header collectors, which will open them up to a true 3" slip-on style collector
2.) Use a 3" Speed Engineering, TSP, or whoever's, Y pipe
3.) Mate that to a 3" to 4" Flowmaster merge
4.) 4" transitioned back down to 3", mated to existing I pipe back exhaust
or...
Just frickin' start over...LOL...
or...
Long tubes and Lane's true duals!
Sadly, I think the last set of Lane's true duals was built about 15 years ago.
Am I old now? Any of y'all ever even heard of Lane's true duals?
Anyway. I'd go true duals redbird or go single 4"
The flowmaster dual 3" to single 4" is a real nice piece and the mufflex 4" is pretty nice and not horribly loud, the one's i've heard weren't anyway.
I’m debating this mod also....I currently have Kooks headers into their older design Y with 3’ cats. The merge doesn’t look so great on it and it goes into a 3’ Borla cat back....
I can’t decide between going with a new Y or mod it to improve the merge into a 3.5 piece of stainless pipe with a cutout and re use the Borla...or swap to the SE true dual exhaust.
I like the idea of using the electric cut out when I want it loud vs the SE and it always being loud and lack of clearance.
Performance wise I’m sure it wouldn’t be much of a difference with the cut out open for my 400ish RWHP combo vs the TD.
The first y pipe on the first page is mine. I run that into a 4in electric cutout with a stock catback so it's quiet when I want it to be. On my setup it made a noticeable difference especially in the higher rpms with my setup.
#33
I think at my power level the Flowmaster 3.5’ merge will do the job and give me a little more clearance around the tunnel mount etc over the 4’.
I’ve read that a single 3.5’ is good for around the 450-500hp range so putting the cut out before it’s reduced to 3’ should do the trick.
