Frothy coolant and seeping hoses
All of your coolant hoses are now contaminated with oil and will start swelling and pop. I've been through this before. You'll need to change all hoses.
After you do you'll have to change the antifreeze a few times to get all the oil out. It's a tedious process. Before you pull the old hoses drain the coolant pinch off the power steering cooler lines to the cooler with vice grips or something and drain the coolant. Then run some water and dawn soap in it and let it get hot and circulate. This will get a considerable amount of oil out before you put on the new hoses.
When you have the hoses off stick a water hose in the radiator and let it run for a while to get as much goo out as possible. I would personally pull the water pump off too and flush the engine with the hose and flush the heater core with the hose. Don't want oil getting on the new hoses.
For the new upper radiator hose get the one for a z28 that doesn't have the cooler in it and you'll get a 1 piece hose.
Rockauto orderlist.
I don't have a thread with step by step instructions for the throttle body bypass mod, but I do have a good photo of it:
For hoses don't forget heater hoses and throttle body hoses, over flow hose from rad to overflow jug, and I can't remember but I think there is another small hose that connects to the radiator.
Yeah if you pull the pump do new gaskets
That's about I can think of at the time
mine.....
https://www.ls1.com/forums/f63/power...l-pics-157864/
And I didn't know the part number then. I went to oreilly and looked at all they had and picked one by size. You just need a tiny one for the power steering. Some manufacturers actually just use a length of metal tubing for a cooler with no fins. It doesn't need anything special. If it says power steering cooler it's surely sufficient unless you're gonna do a lot of road racing or auto x
No, I don't remember the model. It really doesn't matter though. You can get one from most any auto parts store. Just ask for a power steering cooler. There are lots of generic coolers that will work. They are basically one size fits all.
I haven't lost any power steering fluid since the swap. I lost about a quart before I figured out what was going on. I couldn't figure out why I was losing fluid, when there wasn't anything leaking. A guy from work told me about the cooler.
I still get a little sludge on the coolant dipstick. It will probably take a while to get it all out, if I ever get it all out. I did have the heater hoses replaced, and I recommend that you do too.
If so, it is very fortunate that you did not end up with engine oil leaking into the engine cooling system radiator from an engine oil cooler inside of the radiator end tank...
Double check, just in case...
Make sure the engine oil level is not raised up high due to engine coolant being down in the engine oil pan.
Just to clarify, my radiator fluid looks good (Dexcool red/orange). I just get a little sludge on the dipstick. I figure it's probably residual that didn't get flushed out. I haven't checked it lately though. I do keep an eye on the eng temp, and check the radiator fluid occasionally. Everything has been within normal limits since the flush and cooler swap.
These cars don't have oil coolers in the radiator. Just trans coolers. The power steering cooler is in the upper radiator hose and semi common to leak. I've had other makes of cars where the trans cooler leaked in the radiator and mixed water and trans fluid.
