Is my catch can plumbed correctly?
I am having trouble with the idle of my new engine build, and I am starting to wonder if I plumbed the catch can wrong and have affected my metered air in such a way as to make my idle bad.
Engine is hard to cold start then when it does fire up it revs high for a few seconds before it slowly comes down. If I rev the engine in open loop it will rev then stall.
Please see the picture below.
I have one line coming from the passengers side valve cover through a PCV valve to the inlet of the catch can.
Then out of the catch can and into the intake manifold after the TB.
One stand alone hose from the TB to the drivers side valve cover.
in the tune. The Best V8 Stories One Small Block at Time
