Dyno Numbers Mods Sound Right??
SLP Lid
Speed Engineering 1 7/8" headers, no cats
Magnaflow Exhaust
Transzilla 6-Speed transmission
Tuned put down 329HP. Sounds a bit low to me...supposedly tuned for optimum AFM over max hp.
What y'all think?
329 whp - What type of dyno? Lot of other factors too.
Probably about right to pretty good on a correctly set up Mustang Dyno.
I'd be concerned on the typical DynoJet. On a DynoJet I've seen several stock to the air filter, M6 02 LS1 cars make 320 whp to 324 whp
LS1 intake? That's definitely will hold the car back.
The tech said the timing tables and fuel trims were all out of whack and said he tunes for optimum AFM throughout the rpm range, not max horsepower.
The initial run was 258whp. After the tune it did 329hp.
This was with the SLP airbox, LS1 intake, terrible Ebay 1 5/8" headers, a Pacesetter (or similar) y pipe and a questionable Dynomax catback. Also, it apparently has 3.90 gears in it. He said he had to adjust my speedometer, because it was off.
Since that run, I have put Speed Engineering 1 7/8" headers on it, had a 3" y pipe with a Magnaflow merge made, and put on a Magnaflow catback. Once I upgraded the exhaust components, the entire tone of the engine changed and my 2000rpm machine gun popping completely disappeared.
I have not had it dynoed since but I'm sure it's not making less power than it did when I had it tuned.
Just a little more context for the conversation.
The car may have picked up a fair bit of hp with the SE 1 7/8 headers etc. I wouldn't be surprised if redyno'd that the car was 340-350whp on a DynoJet
