LS1 long start when warm
I've got a daily driver 02 T/A WS6 with about 140k miles on the original engine.
Car runs great, no misfires, codes, etc. However, after the car has warmed up and been driven around a bit then turned off, it exhibits a long start. It cranks just fine, but takes 2-3 seconds before it stumble/starts and then it immediately purrs no problem. No issues at all when it's cold first thing in the morning. Every morning it fires straight up with the slightest turn of the key.
Any ideas?
Thanks!
1. try giving it 10-20% throttle when cranking, if that helps it needs less fuel in the cranking table at that temp (or more air)
2. visibly verify fuel pressure is there before cranking (drain back check valve, not all fuel pumps have them, e.g. 450 walbro no check valve)
Its usually too much fuel, most of the time on hptuners boards when people complain about hot starts the knee-jerk reaction is somebody saying "pull out 5-10% fuel each time until it fires up normally"
My 99 TA did it when it was still bone stock
probably the way my fuel system is setup but who knows
After heating up, the first time I crank, it will just keep turning over as long as I hold the key in start position without firing. As soon as I release the start position and crank a second time it fires up instantly.
Even if the first crank is only 1-2 seconds, the second crank always starts straight away.
I havent had had a chance to troubleshoot fuel pressure or IAC yet because I don’t drive it enough to have frequent hot stops (just to and from the office every day). Once I get some free time on the weekend I’ll give it a go and check.
Also clean up the fuel system, new filters (& in-tank sock) , injector cleaners,
sounds like typical inadequate iacv opening due to carbon buildup so try cleaning that first is a great idea
The hard part part is that it’s very intermittent. Sometimes the issue is there, other times not. It does seem to be dependent on how hot the vehicle is, and the outside temperature, with more heat being worse.
Thats just one theory anyways...
