smallest a/c compressor
been triyng to google, searches on different forums. so finally decided to ask.
cool. i ended buying a tubular k member to get as much room. trying to do a turbo 5.3l in that 90 camaro thats in my sig and keep a/c and heat.
do you rememebr which BRP mount you used? was lookin at a couple but couldnt really tell which one would work.
I got mine way back in like 2005 roughly, couldn't see on website. It's basically a steel bracket for the 508 to go with the factory f-body drive parts in place of the variable compressor.May need to call.
1st pic is where the downpipe is going to go. that pipe sitting on the tape is a half inch bigger than what im goin to run.
2nd pic is where the cross over is gonna go from passenger side to drivers side.
Just a side thought here,was recently looking into air cure cerakote header coating, which with good prep & a decent touch up gun,could be fairly easy for skilled diy. Would be nice just to not have to get parts turned over to a coater & be at the mercy of their schedule & quality control. Some stainless or aluminum heat shields for mounts look like a good idea also.
