Well made easy to tune/install MAF?
also i just saw a big maf for sale in the classifieds for like 180 i think. the 104 lids are hard to find used so i will probably have to buy new just like you will have to if you choose to run a 4 inch maf.
as far as the heat soak, i was planning on running an IAT in the lid anyway. honestly i think any of the 5 pin mats have some level of heat soak that we dont want. some moree than others.
But if you use the built-in IAT of the cartridge, it will heat soak. I had mine wrapped in reflective heat shield, and it would show 140+ F in traffic for the IAT. And when the air temp is really like 85, talk about a **** show for how the car acts.
You can get adapter harnesses to let you do it or you can cut and splice wires. It is not too bad to do either way.
One of the worst Internet things to happen to the F car was the idea to de screen the maf. Like mentioned above, the 100mm maf card blocks the throttle opening. You might be able to get away with the truck maf unless you are planning to make max effort power. Between the 85mm truck maf with no card and the 100mm with card, idk which flows more.
As to tuning, copying the maf curve in is very simple. If you do lingenfelter maf they have an excel spreadsheet you can download ready to be copied and pasted.
OP, I'd go with the z06 85mm which should already be de screened from factory. No tuning hassles and I think it will support your combination.
