Build Help, Intake, TB, Knock Sensor, Headers
Looking to add to the car but want/need to keep it emmissions legal (not sure where I'll be moving next, but the probability of it needing to pass emissions is going to be high).
Car is a 1998 TA with the 3.23 factory gears and 4L60E A4 trans. So far I've added an SLP Y pipe and QTP cutout in the I pipe. Also a KN FIPK intake. Future goals may or may not include heads and cam, but that's 2+ years down the road.
I have a 1 grand budget and it's not flexible.
I live close to Vengeance and was going to go get a tune ($325) after I change anything else.
I have done extensive reading about exhaust options. The general consensus is that I won't be able to do LT's with Cats for my budget. It also seems that as far as exhaust goes, by current setup is pretty decent (with the cutout open). It seems that it will flow enough to benefit from adding an LS6 intake.
On to the intake, I've done my reading there as well. Seems like apart from going to a Fast 90-92-102 (there goes the budget) I'm looking at and LS6 intake, Dorman LS6, or Dorman LS2. With that research I've noticed that the Dorman LS2 is going to flow the best, however it takes a good deal of modifying to install that I may not really want to do. Next best being an LS6 intake, however I will need (not so much want) to retain the EGR system my car has incase future inspections are visual. This leaves me with a Dorman LS6 intake as my most budget friendly way to increase flow without extensive fabrication to make it fit.
In researching the installation of the Intakes I've noticed that some mention upgrading or changing in some way the knock sensors. Particularly to allow more room for a tune. Is this true? Is this something I should budget on and do as well? If so, what part am I looking for to pull that off?
Lastly, Does the plan of Dorman LS6 and a tune seem to be my best option at this point? What kind of gains am I likely to see in my car?
What else should I consider (TB, mid length/shorty headers, heads?)
Thank you all in advanced.
All in all part of my avoidance to doing anymore exhaust work for now. In a few more years the car will age itself out of needing emissions checks at all.
What tests will be performed?
All subject vehicles will receive a three-part inspection:- An OBD test to check the vehicle’s emissions control performance history.
- A fuel cap inspection to check for adequate seal.
- A visual inspection of the catalytic converter to check for tampering or removal.
Basically, if they can't see/hear/smell/scan any mods, you are clear.
Do you have any experience with the dorman ls6 intake? Or what gains to expect from a tune at this point?
Thank you for the part listing, what stall would you suggest, and what are some other brands to look at or to avoid? Can this be done by myself in the garage, I'm assuming I would have to drop the transmission to do this?
I like circle d because I have done business with them and I had a great experience. Most people.here use yank I believe, I'm sure they are great too. I used the 3200 I listed and it drive amazing, couldnt tell it was there at all and had some decent kick to it when you floor it. The more expensive 3600 245mm is a little looser, still drives great imo and hits a lot harder. I wouldn't be scared to daily either but the 245 will almost blow your budget out.
I dont think I can drop the trans in my garage either, so my budget would be shot regardless of the converter I picked.
I'm assuming the drivetrain can take a few extra hp from an intake and tune and if I have any left I'll pick up some sub frame connectors.
