Y pipe
Old Nov 22, 2019 | 08:03 AM
jesse maldonado's Avatar
Default Y pipe
So I ordered kooks headers with 13/4 primaries and I was about to order a y pipe when I noticed that pacesetter has a y pipe for their 13/4 primary headers and another for their 17/8 primary headers both with 3 in collectors.so my question is do you really have to use a different y pipe based on that?
thanks in advance
Old Nov 22, 2019 | 08:42 AM
drdave88's Avatar
Probably the same reason you can't smell the number purple.
What are you talking about?
Old Nov 22, 2019 | 08:57 AM
not sure how that got on there,let's try that again.
Old Nov 22, 2019 | 09:08 AM
drdave88's Avatar
Just taking a guess here, but having bigger tubes on the primaries may cause a bit different angle on the pipes, causing the collectors to sit slightly different than the 1 3/4. Just a guess though.
Old Nov 22, 2019 | 10:58 AM
Good guess,I think that makes sense but I believe every other brand uses the same y pipe for both primary sizes
Old Nov 22, 2019 | 04:27 PM
wannafbody's Avatar
Call Kooks and ask them. Mixing brands of headers and y pipes is asking for a headache. Stick with the same brand for both.
Old Nov 22, 2019 | 07:05 PM
RevGTO's Avatar
Pontiacerator
For Kooks only use Kooks. Nothing else is going to fit. And yes, you'll want to use the Y-pipe designed for your primary width if Kooks has spec'd them out for each.
Old Nov 23, 2019 | 01:09 AM
Going with kooks...thanks for the help guys
 Michael S. Palmer
