4l60e transmission change now vu ss ute starts but won't run
Recent 4L60e transmission change in my 2001 vu ss ute after reading these threads maybe it was limp mode...maybe...trans is in but now car starts but won't run...was fine before...have new tps have new oil pressure sensor for a LS1...and car throws no fault codes on scanner...although scanner was not a tech 2...ute starts and runs for 2 seconds and stops...is it fault codes stored and they need to be removed from pcm?? Can an auto sparky do this or does it need to go to Holden and be reprogrammed???
please any help would be great
VATS is kicking in...
So my next move is what?
I seen a thread here where I can bridge it with a resistor to at least get it to start and run properly...i can't even test transmission out because I can't drive it...how can I solve this issue as I live out in the country so no auto sparky around
