hose on DBC TB and valve covers
1. on the top of the TB is a large hole going up at 45 to the passengers side, appears to use a S type hose and go to 2
2. front of passengers side valve cover ,looks like same hole size as 1
3. bottom passenger side of TB small hole that has a hose that runs down the passenger side of the intake, behind it to the drivers side valve cover. At the drivers side valve cover and its a larger hole like in 1 and 2
4. coolant bypass look like it is small hole that runs directly up to the hole on the bottom of the drivers side TB opposite of the one in 3
it appears its the top of TB - passenger valve cover
and drivers valve cover to the passenger lower TB inlet
and coolant crossover to the drivers lower TB inlet
Seems like I am wrong here. I have read about folks funning something to do with the coolant crossover to the radiator or water pump to be high in the coolant circulation for steam
Also my valve cover doesn't have a slot for PCV valve, do I have one? if so where or pls let me know if I should add one
Sorry It wont let me add pics thanks for your help
It looks like the picture below
https://www.ebay.com/p/672301088
The plastic hoses on the TB and valve covers is for the PCV system. Look at post #9 on this thread:
https://ls1tech.com/forums/generatio...-pictures.html
Let me know if you have other questions, good luck.
