08 Avalanche
Old Apr 26, 2020 | 11:54 AM
Mattstone's Avatar
Default 08 Avalanche
Hello 👋
​​​​​​ I hope I’m posting this in the proper place but I have some questions about my build. I bought a 5.3 from a 05 z71 and I’m in the process of rebuilding it. It’s going to go into my 08 Avey (daily) I’m curious can i use the front cam sensor location of the gen 4 with a gen 3 block? I know it has to do with changing the cam gear and re using the front cover but I would love some clarification on exactly what I need to do? Any and all comments are appreciated.
if it matter I’ll be upgrading to a btr stage 2 truck cam
Old Apr 26, 2020 | 03:47 PM
You will also need to change crank reluctors. 05 uses 24x and 08 uses 58x. Completely different computer too.
Old Apr 27, 2020 | 11:04 AM
RichyB33's Avatar
Could use a converter box, could he not?
Old Apr 27, 2020 | 11:05 AM
RichyB33's Avatar
Disregard. I read the OP backward
Old May 6, 2020 | 06:52 AM
Ls7colorado's Avatar
Whats wrong with the engine in the truck??
Just do the cam swap on the engine in the avalanche along with a DOD delete, then you have a ever so slightly better engine to start with.
