CNC heads vs more gear
Old Jun 1, 2020 | 01:49 PM
LS_ELKO41's Avatar
Yukon and USA standard both make them
Thanks. Gears it is then. Now on to finding someone competent enough to install them correctly. Are 4x4 offroad places usually decent with these? I would think so. I got a quote a while back that wasn't cheap at $1k labor plus parts. I'd normally tackle the install as I am with the engine stuff, but I'm not comfortable changing out gears.
Old Jun 1, 2020 | 03:37 PM
98CayenneT/A's Avatar
Don't know how far you are from Rosemount but Master Transmission does gears.
Old Jun 1, 2020 | 04:23 PM
LS_ELKO41's Avatar
Perfect. I'm in the south suburbs so only 20 minutes from therem. Thanks!
Old Jun 10, 2020 | 08:10 PM
LS_ELKO41's Avatar
Christ. $1300 for gears i guess.
Old Jun 11, 2020 | 07:46 AM
LS_ELKO41's Avatar
Isnt $800 steep for labor on a gear install? I thought a dedicated transmission/driveline shop would be able to do the work in a few hours, not 6-7. Ive gotten 3 quotes amd they are all around the same cost.
Old Jun 11, 2020 | 01:46 PM
RB04Av's Avatar
Yeah labor on a gear swap in a properly equipped shop regularly engaged in that business should come to about 2½ - 3 hrs of shop labor; say, $350 ± $50 or thereabouts. Parts should be around $200 for the gears, $125 for the kit, and maybe $50 for misc like fluids, plus a fair markup; say 25 - 33%, which should be maybe $450 - $500 or so total. So, a $800 - $1000 check, drive-in to drive-out.
Old Jun 11, 2020 | 02:17 PM
LS_ELKO41's Avatar
thanks yeah lowest ive gottem quoted is 1290 and highest 1500. I might as well put that towards some ai or tea cnc work.
