Speedmaster electric water pump
Old Oct 10, 2020 | 09:03 PM
fastsspr's Avatar
Originally Posted by Magnet
From what I’m seeing, there’s some questionable bbc pumps that are $120-150-170 but the good ones are $300-400+
if I’m going to go with a “questionable” one then I mine as well go for the speedmaster LS pump IMO
Not set in stone yet, but I’m leaning that way and then doing a full write up on here for those looking for a lightweight and budget option...
Hi, you bought the Speedmaster electric water pump? I'm subscribed to this thread because I'm checking if I jump into one of this electric water pumps too.
Old Oct 16, 2020 | 09:05 PM
tberg725's Avatar
I wish I could go ahead and purchase one of them and feel good about it but with them known to have leaks with my luck I would fire up the car and that thing would probably turn into a sprinkler 😵😵 at the same time it's almost worth a shot to try with the brand name pump costing 800 😞 I'm surprised anther company (brand name) hasn't tried to get into the EWP game and undercut prices they would stand to make alot of money
Old Oct 18, 2020 | 11:39 PM
Magnet's Avatar
I found one for $170 brand new. Just arrived. It will probably take me a bit, but I’ll give a review once it’s on.
Old Oct 19, 2020 | 12:48 AM
FCar2000TA's Avatar
Veteran: Air Force
If this is the same Speedmaster that did LS1/2/6 heads, it is Chinese junk. Also known as Procomp.
Old Oct 19, 2020 | 09:57 AM
Magnet's Avatar
Originally Posted by HioSSilver
There ya go
When i had my ewp rebuilt i had them leave the inner supper and bearing off for the idle pulley. Just letting ya know because it looks a little different.
Thanks for the pics! What percent underdrive is that and what size belt did you end up running?
Old Oct 20, 2020 | 09:55 PM
HioSSilver's Avatar
That's a ati on it. I forget what size for it and the belt.
Old Oct 26, 2020 | 08:30 AM
tberg725's Avatar
You went with the speed master pump? If so why did you need the rebuild? You had it rebuilt out the box? Hell for 170 I'm really considering buying this if people are really having good luck with this
Old Oct 26, 2020 | 11:08 AM
Magnet's Avatar
Nah his was a meizere, but he is showing me his belt routing to keep the power steering but also switch to a "race style" water pump that has no pulley in the middle.
Old Nov 10, 2020 | 09:43 PM
fastsspr's Avatar
Are you already installed your EWP?
