Terminator X MAP Sensor help!!!
Old Jul 17, 2020 | 08:57 PM
kimbalmlq4's Avatar
Default Terminator X MAP Sensor help!!!
Hi all, I'm in a kerfuffle right now and have a questions about MAP sensors.
TL;DR Can I use a 2 bar MAP sensor while telling the ECU that its a 1 bar?
In the instructions for Terminator X, it specifies "Terminator X base calibrations require using the GM (or parts store equivalent) 2.5 bar MAP sensor [12592525]. Failure to do so may cause engine damage", but at that exact same step in the set-up after selecting "No power adder", theres 3 MAP sensor options; "Integral 1 bar", "Holley 538-24" and "Holley SS 554-133". I'm not dyslexic but had to double take, none of those sensors looks like the '12592525'. I currently have a 2 bar installed right now (12580698) that plugs directly into the harness without an adapter pigtail (12592525 requires one) or mangling the EFI harness (both other listed 1-bar sensors require cutting and splicing and dicing). Instructions also say any sensor can be configured using the software. I have neither the software nor the CAN cable needed, I do have a 12592525 MAP sensor though.
She doesn't run super hot right now (the engine has less than an hour of run time) and I'm going through the variables to troubleshoot before driving any more. She dies at decel creeping to a stop almost every time if I don't give it gas, also on decel after free-revving in neutral/park. I want to take advantage of the self-learning feature and do as much as I can myself because $700 for dyno time is not up my alley.
Old Jul 18, 2020 | 03:22 PM
kimbalmlq4's Avatar
So looking at the ECU monitors, I answered my question, no I can't use the 2 bar when the ECU is calibrated for a 1 bar. ECU is reading 51kPa at stall (atmpspheric pressure) but ACTUAL atmospheric pressure is 101.xxkPa. I think what I will do is tell the ECU that the car is boosted such that the MAP tables are calibrated for the 2.5bar sensor, run the 2.5bar sensor but not do anything with the timing tables for timing retard. This definitely explains why throttle response is terrible, takeoff is terrible, decel is terrible but sustained RPM driving and idle following warmup is ok.
Old Aug 14, 2020 | 05:46 PM
Old Geezer's Avatar
Try getting the tools to diagnose and tune the system.....
Old Aug 14, 2020 | 07:21 PM
pdxmotorhead's Avatar
I've been finding thier tech support pretty helpful via email, at least while I'm sorting out the correct part numbers.. to purchase one.
