Oil pump question...
Old Dec 18, 2020 | 08:22 AM
wannafbody's Avatar
Default Oil pump question...
I have a 09 Silverado with the 5.3 that has a collapsed lifter and low oil pressure. Does the oil pan need to be removed in order to replace the oil pump?
Old Dec 18, 2020 | 08:58 AM
wretched73's Avatar
At minimum, you have to lower the pan, It would be way easier if you could drop the pan.
Old Dec 18, 2020 | 09:02 AM
biketopia's Avatar
I didn't drop mine when I did the DOD delete and swapped out chain tensioners. It's nerve racking and tight access but 100% can be done without lowering the pan.
Old Dec 18, 2020 | 09:45 AM
wannafbody's Avatar
I'm assuming that a new pump comes with more than 1 o ring. Which is the correct o ring for the 5.3?
Old Dec 18, 2020 | 10:50 AM
Depends on the pickup tube end. If there is a groove around it close to the end, it's the fatter one. If just straight tube, the thinner one.
