Coolant crossover pipe - where does this part go?
Old Mar 8, 2021 | 11:23 AM
momofx's Avatar
Question Coolant crossover pipe - where does this part go?
Working out the kinks in a LSX Supercharged C5 I just got (original owner had passed away shortly after having the car put together) and I see they ran the part that is circled in the picture is going to the side cooler on a Dewitts radiator and the return from the cooler to the overflow tank... Is that correct or where does it go? I don't get why they would run the crossover to the side cooler??
I actually wanted to use the side cooler for an engine oil cooler setup but I also got a B&M oil cooler I could use...
* Picture is just generic one I found but its the same kind of pipe *
Old Mar 8, 2021 | 12:31 PM
RB04Av's Avatar
On most LS motors that usually goes to the water port across the bottom of the TB, then to the coolant recovery tank. Looks like that one might go straight to the tank.
Not sure what you mean "side cooler", unless you're referring to either an integral oil or trans fluid cooler in a tank.
Old Mar 8, 2021 | 08:34 PM
01CamaroSSTx's Avatar
Yep
That connects by way of a rubber hose to a small port on the radiator and you may have to drill and tap one on the radiator yourself if you don't have the correct one.
Old Mar 9, 2021 | 06:13 PM
momofx's Avatar
Yep
It is a Dewitts and has the oil cooler so they are using that for the crossover pipe and then the other side goes to the coolant tank. Idk if that is ok like that...
Old Mar 9, 2021 | 06:23 PM
RB04Av's Avatar
Using what for the crossover pipe?
Old Mar 9, 2021 | 07:33 PM
momofx's Avatar
Let me explain, the port on the crossover pipe (circled in the pic) goes to the auxiliary cooler on the radiator and the other end of the cooler goes to the surge tank / coolant tank, soooo they are using the cooler that comes on the radiator this way and Im not sure if thats right or ok....
Old Mar 9, 2021 | 08:02 PM
RedXray's Avatar
My radiator didn't have the nipple for the steam vent return. All you have to do is re-route it into the cooling system. Some without the radiator nipple hack the upper radiator in half and install an adapter to feed back into the system. It looks crappy with the extra hose clamps and the extra cost of the parts. I simply tapped the water pump housing and added an 1/8" NPT nipple.
Upper hose adapter
Attachment 712348
Old Mar 9, 2021 | 08:51 PM
CattleAc's Avatar
Yeah, I like the water pump drill and tap method myself. This is the 5.3 in my wagon...
Old Mar 10, 2021 | 12:16 AM
momofx's Avatar
Cool
Is that your wagon in your profile pic??! Oh man do those bring back memories!! Good times when the world was not near as insane as nowdays...
Old Mar 10, 2021 | 07:49 AM
RB04Av's Avatar
Not really, that's kinda nonsense. Involving the oil cooler in that is about like going from DC to Baltimore by way of Salt Lake City.
The WP method is the standard way of setting that up when there's no coolant tank, radiator nipple, etc. Very neat and orderly way of handling it. You can get the little coolant tube off of a truck and make a much neater version of it than with what you've got now. Or, if you have the coolant tank, just route straight to that, without the oil cooler.
Old Mar 10, 2021 | 11:13 AM
RonSSNova's Avatar
I would route it as close as possible to the stock C5 routing.
The dewitts radiator has those provisions.
I have a C5.
Old Mar 10, 2021 | 11:35 AM
CattleAc's Avatar
Yep. It is.
Old Mar 15, 2021 | 10:12 PM
momofx's Avatar
I have a C5.
Ok, so you are saying that the way they have it on my Dewitts (using the side cooler) is correct?
Old Mar 16, 2021 | 03:35 PM
RB04Av's Avatar
No.
It should not use the "side cooler" in any manner way shape form or fashion. That's for oil or trans fluid.
It should go straight to coolant somewhere. Preferably the suction (cold) side of the system, but either would work.
Old Mar 16, 2021 | 05:03 PM
No.
It should not use the "side cooler" (tranny cooler) in any manner way shape form or fashion. That's for oil or trans fluid. ONLY!!
TRUTH. As said above...
Old Mar 17, 2021 | 11:54 AM
momofx's Avatar
Ok thanks, I was thinking that it did not make any sense why the oil cooler was used. Well I gotta change the water pump due to bad bearing noise so now would be the perfect time to reroute it...
Soooo, should I route it to the coolant reservior?
Old Mar 17, 2021 | 12:03 PM
Only if the reservoir is part of the pressurized system.
Old Mar 18, 2021 | 03:45 AM
TTur1996's Avatar
That is supposed to be a return going to the radiator only. Not the water pump or anywhere else for that matter. It flows constantly, regardless of what the T-stat is doing. The pressure in the radiator controls the flow from it. You take that line off the radiator and turn the electric water pump on and it will shoot water like thirty feet. By pressurizing it from the water pump you are fighting the flow from the lines because that is not the direction of the flow. Also, if you have a motor with the back 2 ports blocked. Get rid of the blocks and use a 4 corner line setup. That blocked setup causes air to get trapped and then causes hot spots.
Old Mar 18, 2021 | 09:44 AM
On an fbody car the steam port connects to the second port under the radiator fill cap. Top one goes to the overflow.
Old Mar 19, 2021 | 10:06 PM
patSS/00's Avatar
Definitely don't do that. That will cause hot coolant to boil out of the reservoir. The same thing will happen on an fbody if you accidently reverse the two hoses that connect under the radiator cap (the top one goes to the reservoir).
